Old 06-19-2015, 08:00 PM   #1
CablerNC
CablerNC's Avatar
Default 39 Deluxe ground?
Is the ground from the battery a strap or cable and what should it be grounded to? Thanks in advance!
CablerNC is offline   Reply With Quote
Old 06-19-2015, 08:45 PM   #2
adileo
adileo's Avatar
Default Re: 39 Deluxe ground?
My 39 is a strap grounded from battery to firewall
adileo is offline   Reply With Quote
Old 06-19-2015, 09:05 PM   #3
G.M.
You should put another cable from the ground on the firewall to the engine. G.M.
www.fordcollector.com
Old 06-19-2015, 09:20 PM   #4
CablerNC
CablerNC's Avatar
Firewall to a heater bolt!
Old 06-19-2015, 09:34 PM   #5
Drbrown
Drbrown's Avatar
To enhance engine starting, I choose to use a cable to ground to the starter motor body, that also being the engine block, and from the engine block to both the firewall and frame. In addition, I run one #8 ground wire to the areas where lights are located at front and rear of the car. Obviously none of this is "stock" but it improves and maintains the performance of the electrical system.
Drbrown is offline   Reply With Quote
Old 06-19-2015, 10:05 PM   #6
Fredb_
Fredb_'s Avatar
Not stock, but on my 38 6v flathead I went overkill on grounds. I made my own cables, one to normal position on firewall and one to bellbousing near starter. I may even have a braided strap from firewall to bolt on intake. Like I said, overkill, but no problems with poor ground. I also re-wired my car and ran a ground to all lights. Don't like to depend on body for ground.
Fredb_ is offline   Reply With Quote
Old 06-21-2015, 07:44 PM   #7
WestCoast
never use an exhaust manifold bolt for a ground, the heat will cause to much resistance and wont provide a good ground
WestCoast is offline   Reply With Quote
Old 06-22-2015, 09:39 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
really? dd
Click Links Below __
T5 W/TORQUE TUBE
