Old 05-30-2015, 08:56 PM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default Pan Gasket Questions
I had a pin hole leak in the oil pan so I'm changing pan and need to replace gaskets they were new but looked like bacon . And the back of the pan was bent a little where it sits on the cork seal . The mark from the pan ran right out to the edge of the cork seal possible leak ? So I have a couple of questions do I trim the pan rope seal it sticks up a little ? And does the pan gasket go on the engine first so the tabs go into the groove for the cork seal at the rear ? then the cork seal ? And would brush on gasket sealer do the job ? Thanks . This was a new build but has been sitting 6 - 8 years .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 05-30-2015, 09:30 PM   #2
Mitch//pa
Default Re: Pan Gasket Questions
http://www.sacramentocapitolas.org/s...et-Article.pdf
Old 05-30-2015, 09:53 PM   #3
Dennis Pereira
Thanks that answers all my questions .
Dennis in Kelsey ca
Old 05-31-2015, 10:19 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Trick idea, Mitch, for posting that article. Saved us from posting 5 PAGES of "TIPS"
Dad W.
"THE ASSISTANT GURU OF STUFF"
Old 05-31-2015, 11:02 AM   #5
Dennis Pereira
Using the information in the link says to replace rear cork seal Dry ? Les Andrews vol I says place the soaked rear main cork gasket Oil or water ? I'm thinking the sealer will work a lot better dry .
Dennis in Kelsey ca
Old 05-31-2015, 11:31 AM   #6
Cape Codder
Cape Codder's Avatar
I did mine several years ago using those instructions and measured very carefully what size he said to cut the rear main cork gasket and it was too short. I proceeded to install the second one and cut it according to the rear main.
Cape Codder is offline   Reply With Quote
Old 05-31-2015, 01:32 PM   #7
BILL WILLIAMSON
If it's a bit too long, put in the ends, poke it in, here & there, to form "waves", then poke in the waves. THEN, it'll be compressed & WON'T shrink & leak, later. I've been doin' this crap a LOOOOONG time, yes, I'm OOOOOLD! Experience is the best teacher
Bill W.
Old 05-31-2015, 03:27 PM   #8
Dennis Pereira
I tried that Bill way too long had to cut to fit . The first one broke into pieces way to old lol .
Dennis in Kelsey ca
Old 05-31-2015, 08:32 PM   #9
BILL WILLIAMSON
Always best to use "fresh" gaskets My home help Gal sez I'm OOOOOOLD, but "FRESH"
Bill W.
