Could someone post pictures of upper tailgate/hinges and how is it attached?
I donno if this will help you much--pics aren't very good. The upper tailgate has a resessed area at the top of the jam to accept the two hinges. I have mine set up with gas shocks for openers.
Hope this helps...slim |
Remove the trim on the inside. Then use an extension to reach the screws. Use care removing them, so the phillips head is not stripped. I used a 3/8 drive phillips head. Might require using a impact driver, the hammer type, not air or electric drive style. Have two people holding the tailgate, while removing the screws from the inside. This is a tough job. I tore my original headliner doing this, and thought all was lost. Nick Alexander's upholsterer, saw it and repaired it in an hour. You would never know it was torn. Let us know how it goes.
Henry Ford designed the flathead without the aid of a computer. |
