Old 04-14-2015, 12:02 PM   #1
Terry/Iowa
Terry/Iowa's Avatar
Default Electrical/Ground - Solved
First of all, thanks for all the help and suggestions. The problem turned out to be in the cut off switch I have on the cable to the starter. Originally when I cleaned the ends I didn't think to disassemble the switch to clean the inside and the screw that cuts off the voltage. I did that finally and it seems to have solved the problem. It's nice to have something that simple go wrong once in a while so I can feel like an idiot. Anyway, thanks for the advice.
Terry/Iowa is offline   Reply With Quote
