Old 03-24-2025, 11:56 AM   #1
ssffnomad
ssffnomad's Avatar
Default Horn Buttons.
Hello. I have a 39’ Deluxe steering wheel.
Do not have a Horn Button.
It’s going in our 36’ Coupe build.
I do not need the Rod , as we are not using a bottom of box switch.
Question is, do you know if a 36’ horn button will fit a 39’ wheel ?
ssffnomad is offline   Reply With Quote
Old 03-24-2025, 05:46 PM   #2
fordv8j
fordv8j's Avatar
Default Re: Horn Buttons.
I have a horn button for a 38 Deluxe, complete except rod is not on it, $40.00 plus shipping--304-462-5332==J Parsons==Normantown, [email protected]
fordv8j is offline   Reply With Quote
Old 03-24-2025, 05:59 PM   #3
KiWinUS
KiWinUS's Avatar
To ANSWER your question. No a 36 will not fit your 39 wheel correctly.
Old 03-24-2025, 08:20 PM   #4
johndee138
johndee138's Avatar
I used the hole that the throttle rod went through for a small button that honks my horn, the stock setup was unreliable.
johndee138 is offline   Reply With Quote
Old 03-25-2025, 09:52 AM   #5
TJ
TJ's Avatar
The 38 button will fit your wheel. If you are going to install a separate horn button and just want to fill the hole in the steering wheel you can use a 30-31 Model A hubcap. I did this years ago when I put a '39 banjo wheel on a '36 Ford.
