Old 03-13-2015, 06:20 PM   #1
Maclab58
Maclab58's Avatar
Default HC head frustration
Put a snyders 5.5 head on my cabriolet a few weeks ago........... It has been a roller coaster! It's a balanced engine that ran very well prior to the head change, while it certainly has more power it doesn't run as smooth. I have replaced the plugs, coil, rotor, cap, coil, cleaned the carb, replaced the fuel filter, timed it 3 times, played with the GAV and spark advance......... Suggestions???????? I'm almost ready to pull the head off and put the stock head back on.
Maclab58 is offline   Reply With Quote
Old 03-13-2015, 06:22 PM   #2
Maclab58
Maclab58's Avatar
Default Re: HC head frustration
Add to that I traded carbs just now with not much improvement.
Old 03-13-2015, 06:24 PM   #3
Mitch//pa
is this a double thread??
Old 03-14-2015, 07:50 AM   #4
1931 flamingo
1931 flamingo's Avatar
I think so.
Paul
Old 03-14-2015, 03:48 PM   #5
rocket1
I would take a compression check or a leak down test because basically all you did initially was to change the head and gasket.I would also check the dist.because that was also removed,especially the pigtail on the lower plate.
rocket1 is offline   Reply With Quote
Old 03-14-2015, 07:48 PM   #6
zzlegend
zzlegend's Avatar
Why don't this one get deleted buy the OP?
zzlegend is offline   Reply With Quote
