I have a 59 engine with 59AB heads that I traded for several years ago. It has about 14,000 miles since a factory overhaul according to the last owner which I trust. I would like to mount it on a mobile test stand so I can start it occasionally. I have all of the components to do this, even a `41 pickup transmission and a `35 radiator.
I am sure some of you have test stands. Please post pictures. Give me some ideas.
Son, you will never blow an engine up in high gear. |
Go to the search tab, advanced, then type in engine test stands, then choose early V8 in discussion forums. There are three threads with test stands and pics.
Here's mine with an 8BA with 8BA water pumps and the Mercury bell housing.
Another shot
Cecil,
I like that. Thanks for posting.
I'd show you mine,but, It's an old truck tire buried in the snow.
Sent you a few pic Bud..if you need more,just let me know,.
DON P |
Forgot to mention Bud, get good rolling wheels with brakes,makes things easy to roll around. Think I found mine at the flea market,HF also has them,if you need the height ,let me know.
DON P |
#10 | |
![]() Quote:
Good suggestion Don. I like the looks of the one you built. Bud
The HF heavy duty engine stand can provide most of the materials you need to build one very inexpensively. I have 4 done 5 of those.
But I have also used a 15x7 steel wheel with a 205x70x15 blackwall inflated to ~25 PSI. Strap it to a movers dolly and it becomes portable. |
#13 |
Yep!! have a coupls cinder blocks for that. All I need is and oil pressure gauge.
#14 |
![]() ![]() ![]() ![]() Finally figures out how to post a picture,the radiator hangs from the front posts by welding some legs that stick out,couldn't find a finished pic .If I leave the transmission on I use a sissor jack to hold up rear
DON P |
