Old 01-17-2015, 12:39 AM   #1
Bob from Northport
Bob from Northport's Avatar
Default Ford 94 Carburetor question
We have a two carburetor set up on a 28 Roadster truck in the shop. On the midway side of both carb's, someone has threaded short bolts into a hole that is about midway up the body. I can not locate a diagram showing what the part should be that really should be in the hole. Can anyone offer a reference to ID the part missing from the carbs???
Thanks!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-17-2015, 12:48 AM   #2
jimvette59
jimvette59's Avatar
Default Re: Ford 94 Carburetor question
Looks like the vacuum lines to the 8BA distributor is plugged off on both carburetors . JMHO
jimvette59 is offline   Reply With Quote
Old 01-17-2015, 12:51 AM   #3
Bob from Northport
I'll write down the model number tomorrow and add it. By looking at some rebuild kits, the hole size is about the size of a power valve. Someone has put 9/16" short bolts into each hole on the side of the carb.
Bob from Northport
Northport, Michigan
Old 01-17-2015, 01:08 AM   #4
Bob from Northport
This is someone elses carb photo, but the bolt protruding sideways is the one I am concerned with. What is the hole for??
Bob from Northport
Northport, Michigan
Old 01-17-2015, 01:39 AM   #5
Y-Blockhead
Y-Blockhead's Avatar
JimVette is correct. That is where the vacuum advance distributor would connect for a later year car. Holley 94's were used on Ford Y-Blocks up until the mid 50's. Holley 94's are repro'd by Edelbrock today. It would look a lot cleaner if you replaced the bolt with the proper plug.
Old 01-17-2015, 09:34 AM   #6
Bob from Northport
I appreciate the help. Where can I find these plugs?
Bob from Northport
Northport, Michigan
Old 01-17-2015, 11:08 AM   #7
jimvette59
jimvette59's Avatar
Thanks!
Like I said those are vacuum ports to the distributor. They have a 1/8th tubing fitting. These are not needed on a Model A.
Old 01-17-2015, 01:30 PM   #8
Archie Cheda
Archie Cheda's Avatar
Bob,
If you cannot find a plug, the fitting is (as Jim posted) for 1/8th inch tubing. It is a compression fitting which should be available at any good auto parts store and if you put a piece of brass rod in & file it flush. (You could solder it in, but the compression nut will hold & seal it fine.)
Archie
P.S.: See pic below:
Archie Cheda is offline   Reply With Quote
