The Ford Barn
-   -   Ford 94 Carburetor question (https://www.fordbarn.com/forum/showthread.php?t=159319)
Bob from Northport 01-17-2015 12:39 AM
We have a two carburetor set up on a 28 Roadster truck in the shop. On the midway side of both carb's, someone has threaded short bolts into a hole that is about midway up the body. I can not locate a diagram showing what the part should be that really should be in the hole. Can anyone offer a reference to ID the part missing from the carbs???
Thanks!
jimvette59 01-17-2015 12:48 AM
Re: Ford 94 Carburetor question
Looks like the vacuum lines to the 8BA distributor is plugged off on both carburetors . JMHO
Bob from Northport 01-17-2015 12:51 AM
I'll write down the model number tomorrow and add it. By looking at some rebuild kits, the hole size is about the size of a power valve. Someone has put 9/16" short bolts into each hole on the side of the carb.
Bob from Northport 01-17-2015 01:08 AM
This is someone elses carb photo, but the bolt protruding sideways is the one I am concerned with. What is the hole for??
Y-Blockhead 01-17-2015 01:39 AM
JimVette is correct. That is where the vacuum advance distributor would connect for a later year car. Holley 94's were used on Ford Y-Blocks up until the mid 50's. Holley 94's are repro'd by Edelbrock today. It would look a lot cleaner if you replaced the bolt with the proper plug.
https://farm9.staticflickr.com/8651/...46ede644_z.jpg
Bob from Northport 01-17-2015 09:34 AM
I appreciate the help. Where can I find these plugs?
jimvette59 01-17-2015 11:08 AM
Thanks!
Like I said those are vacuum ports to the distributor. They have a 1/8th tubing fitting. These are not needed on a Model A.
Archie Cheda 01-17-2015 01:30 PM
1 Attachment(s)
Bob,
If you cannot find a plug, the fitting is (as Jim posted) for 1/8th inch tubing. It is a compression fitting which should be available at any good auto parts store and if you put a piece of brass rod in & file it flush. (You could solder it in, but the compression nut will hold & seal it fine.)
Archie
P.S.: See pic below:
