Old 08-01-2016, 11:29 AM   #1
keeeef
Default Oil Filler tube
The oil filler tube has worked loose at the base on my 29 Sedan and started to weep oil. How is this fixed in normally?
Thanks
keeeef is offline   Reply With Quote
Old 08-01-2016, 11:42 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Oil Filler tube
I would tin the base with solder.
Old 08-01-2016, 11:48 AM   #3
keeeef
Ok. Can I pull it right out to clean it up?
Old 08-01-2016, 11:59 AM   #4
Bruce
Bruce's Avatar
Keeeeef, Judging by your use of a flexi (corrugated) return hose, your car is not headed for the high point judges. Use an easy, modern, but not-JS fix. Just pull the tube out and put on some gasket maker and tap it back in. The red stuff would be fine.
Put a 2X wood block over the open end so you don't mash it up.
Bruce is offline   Reply With Quote
Old 08-01-2016, 06:20 PM   #5
Tom Wesenberg
I made a tool to pull the tube straight out. If your's is loose enough to leak then it might pull straight out by hand.
