Oil Filler tube 1 Attachment(s)
The oil filler tube has worked loose at the base on my 29 Sedan and started to weep oil. How is this fixed in normally?
Thanks |
Re: Oil Filler tube I would tin the base with solder.
Re: Oil Filler tube Ok. Can I pull it right out to clean it up?
Re: Oil Filler tube Keeeeef, Judging by your use of a flexi (corrugated) return hose, your car is not headed for the high point judges. Use an easy, modern, but not-JS fix. Just pull the tube out and put on some gasket maker and tap it back in. The red stuff would be fine.
Put a 2X wood block over the open end so you don't mash it up. |
Re: Oil Filler tube 4 Attachment(s)
