I am restoring a 1931 Victoria leatherback, when I purchased the car a new wood frame had been installed in the car. None of the wood framing has wood presevative on it. Should I remove all the framing and put wood presevetive on it or not?
Probably not. The lifestyle this vehicle will live from here on out will likely mean it is stored inside a garage and rarely seeing inclement weather. IMHO, it is not worth the effort at this point to seal the wood.
The original wood had a preservative on it. Do not remove the wood to preserve its fit. Apply a sealer such as Thompson's Water Sealer. Spray it into places where a brush doesn't fit.
Bob Bidonde |
Thanks for you help.
Leonard |
I'll bet you can even twist a few pipe cleaners together and bend them to fit around hidden corners to apply the sealer.
Tom,
Good idea, the pipe cleaner! Thanks.
Bob Bidonde |
