Diagram needed for electric novice who hasn't the slightest idea of electric WIREING. Your assistance would be most appreciated. John.
Some more info would be helpful. What year vehicle? Stock wiring? Are you going to use a add on turn signal switch. There are small transisterized switches. The switches usually come with diagrams on where to cut and ad the wires. I use relays and a subminiture center off switch.
As Andy said, you first need to decide what you are going to use to activate the turn signals. I, like Andy use a switch setup because I'm not a fan of the add on selectors on the column. But they are the easiest way to go. I would suggest you decide on a selector, order it and then if you don't understand the instructions that comes with it ask a question. If you are interested in a switch setup I can provide you that information. It is not difficult, but takes a little more effort than an add-on.
Not trying to steal this thread only Borrow it for a bit !!!
Jseery I would be interested in a switch set up { how does it work } [ I don't mean how well it works ] |
These diagrams are not mine, copied for others. There is a lot of good information at the site: http://www.how-to-build-hotrods.com/hot-rod-wiring.html
Thank you all for input for my 1941 ford coupeSD . Diagrams for switch instal are great also.
