The Ford Barn
-   -   Need directional light WIREING diagram 6v pos ground (https://www.fordbarn.com/forum/showthread.php?t=153429)
josh1331 10-30-2014 03:52 PM
Diagram needed for electric novice who hasn't the slightest idea of electric WIREING. Your assistance would be most appreciated. John.
Andy 10-30-2014 04:00 PM
Re: Need directional light WIREING diagram 6v pos ground
Some more info would be helpful. What year vehicle? Stock wiring? Are you going to use a add on turn signal switch. There are small transisterized switches. The switches usually come with diagrams on where to cut and ad the wires. I use relays and a subminiture center off switch.
JSeery 10-30-2014 07:27 PM
As Andy said, you first need to decide what you are going to use to activate the turn signals. I, like Andy use a switch setup because I'm not a fan of the add on selectors on the column. But they are the easiest way to go. I would suggest you decide on a selector, order it and then if you don't understand the instructions that comes with it ask a question. If you are interested in a switch setup I can provide you that information. It is not difficult, but takes a little more effort than an add-on.
BILL WZOREK 10-31-2014 06:46 AM
Not trying to steal this thread only Borrow it for a bit !!!
Jseery I would be interested in a switch set up { how does it work }
[ I don't mean how well it works ]
JSeery 10-31-2014 10:35 AM
4 Attachment(s)
These diagrams are not mine, copied for others. There is a lot of good information at the site: http://www.how-to-build-hotrods.com/hot-rod-wiring.html
Ralph Moore 10-31-2014 12:35 PM
I used these diagrams, not too hard to install, conversion box was not expensive from my local trailer store.
josh1331 11-01-2014 11:27 PM
Thank you all for input for my 1941 ford coupeSD . Diagrams for switch instal are great also.
