Old 08-12-2014, 09:59 PM   #1
loumo
Default Mating Original Rear Fenders to Brookville Rear Quqrter Panels
Mating original ‘29 rear fenders to Brookville 1929 Roadster quarter panels.
I am having a problem getting proper spacing for the weltjng between an original undamaged rear fender and a Brookville quarter panel, I can’t get the space to be narrow enough. The problem is, the mating angles of the Brookville 1/4 panel and the fender are different . When bolted in place the mis-matched angle of the ¼ panel keeps the fender too far away to allow a tight fit of the welting.
Has anyone had the problem and come up with a solution?
loumo is offline   Reply With Quote
Old 08-13-2014, 08:15 AM   #2
ericr
ericr's Avatar
Default Re: Mating Original Rear Fenders to Brookville Rear Quqrter Panels
yes, I have had the same problem and it was extremely frustrating. I found that buying the better-quality running board aprons, with the original-design offset flange on the one end, helped. as far as the rest of the fit, I ended up slotting out a lot of holes, both on the fender and the running board, to get a half-ass fit. I still could not tighten down the fender completely on one of the mounting bolts.
See pm too.
ericr is offline   Reply With Quote
Old 08-13-2014, 12:02 PM   #3
Karl Wescott
Karl Wescott's Avatar
Short of slicing and dicing on the quarter panel to make it correct here is a low tech solution.
First, do the splash apron thing and slotting thing per Eric.
Second, get the fenders as straight and accurate as you can.
Now the big trick. Wax the fender with a mold release wax. Prime the wheelwell where the fender interfaces to prep for adding plastic body filler. Slather copious amounts of body filler to the area of gaposis. Bolt the fender to the body before the body filler hardens, the excess filler will extrude out. Allow the filler to fully harden. Remove the fender (it should release easily if is waxed properly). Grind and sand excess body filler from the body. Perfect fit... just like the body was made for the fender.
Karl Wescott is offline   Reply With Quote
Old 08-13-2014, 04:33 PM   #4
Dennis Pereira
Dennis Pereira's Avatar
Seems it would need to be slow setting filler to have time to bolt a fender on . Good luck with that .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 08-14-2014, 05:26 PM   #5
brito36
The filler will set slower if you add less hardener, or work in a cooler garage or in the evening.
brito36 is offline   Reply With Quote
