Old 05-11-2014, 05:28 PM   #1
P.S.
Default Tudor overweight?
I had to make a run to the dump today, and decided to use the Tudor so I could get it on the scale and find out what it weighs (for curiosity's sake and to calculate a total trailer weight if it was on a trailer).
Total weight? 2720 lbs.
That does include my 190 lbs., a full tank of gas, and the bag containing the jug of used motor oil and a small bag containing oil filter stuff.
I thought the Tudor was supposed to weigh just over 2100 lbs.??? What has caused my 31 to be so overweight?
P.S. is offline   Reply With Quote
Old 05-11-2014, 05:49 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Tudor overweight?
Paul,
I think you need to put the General on a diet
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-11-2014, 06:18 PM   #3
ronn
maybe the scale was out of wack...............
Old 05-11-2014, 06:31 PM   #4
39topless
Maybe you should vacuum the car before it's weighed.
39topless is offline   Reply With Quote
Old 05-11-2014, 06:49 PM   #5
Jon
Jon's Avatar
I've weighed my 29 Tudor twice. 2720 and 2640. Don't recall how much gas was in it either time, but that could account for the difference.
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 05-11-2014, 07:15 PM   #6
machine girl
maybe to much bondo! not really just having fun.
machine girl is offline   Reply With Quote
Old 05-11-2014, 08:16 PM   #7
spdway1
spdway1's Avatar
You need to see if it is actual weight or gross ton. Most drive on dump, gravel pit and scrap yard scales are gross ton.
spdway1 is offline   Reply With Quote
Old 05-11-2014, 08:25 PM   #8
MrTube
MrTube's Avatar
I can't find anything on this online. What is "gross ton" and how does it differ from actual weight?
MrTube is offline   Reply With Quote
Old 05-11-2014, 08:48 PM   #9
P.S.
Gee, thanks, Mike! Yea, The General is pretty obese. But, sorry M.G., no bondo in the car. Maybe vacuuming it out might make a difference... As long as the vacuum was strong enough to remove the nut behind the wheel.
The drive-on scale at the landfill measures in pounds. It's a digital scale and fairly accurate, I am told. However, I cannot guarantee that fact. A full tank of gas should weigh around 80 pounds.
So, is 2500 pounds (without driver) about right for a dead stock 31 Tudor Model A? Maybe Henry weighed them without wheels, gas, oil, water, etc.??
The whole point of this exercise is I am trying to do whatever possible to improve the fuel economy.
Old 05-11-2014, 08:57 PM   #10
MrTube
MrTube's Avatar
How much does the water in the cooling system and oil in the engine, trans and differential weigh? I'm sure those were not included. What about your glass, is it original?
Old 05-11-2014, 09:00 PM   #11
bikejunk
you= 190
gas and oil in engine and in jug say 100 lb. (gas is 6lb gallon)
spare tire and tube (spare tire did not come with car) say 40 lb
3 gallons of water say 30 lb. still =2,460 + about 250lb of tools under the rear seat = getting closer
bikejunk is offline   Reply With Quote
Old 05-11-2014, 09:06 PM   #12
mhsprecher
mhsprecher's Avatar
You know, we all gain weight as we age. Maybe your car did, too.
mhsprecher is offline   Reply With Quote
Old 05-11-2014, 09:45 PM   #13
Tiny
Tiny's Avatar
You don't have old stale air in the tires do you. As it ages it absorbs atmosphere making it heavier. Try letting all the air out and refilling with fresh!!
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 05-11-2014, 09:48 PM   #14
P.S.
Ha ha!! You guys are just full of them tonight!
Maybe I need to fill the tires with helium...
Old 05-11-2014, 10:11 PM   #15
Fred K-OR
Fred K-OR's Avatar
May want to try a state highway scale just to compare weight from another scale. Here is Oregon you can drive right on and it tells you the weight.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-11-2014, 10:26 PM   #16
Tiny
Tiny's Avatar
Helium could hurt!!!!
Blackwall Panthers
Nor Cal chapter
Old 05-11-2014, 10:27 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
I thought the stated weight of a Tudor was just over 2400 pounds.
Old 05-12-2014, 02:13 AM   #18
Mike V. Florida
Mike V. Florida's Avatar
1931 service letter, printed in The Restorer Magazine, Volume 33, Issue 1, Pages 30 - 33
Tudor Sedan 2375lbs
Old 05-12-2014, 09:26 AM   #19
marc hildebrant
marc hildebrant's Avatar
Were you in the car when it was on the scale ?
Marc
marc hildebrant is offline   Reply With Quote
Old 05-12-2014, 09:47 AM   #20
P.S.
Marc
Yes. I weigh just a little over 190 depending on what I'm wearing. Maybe I should drive over there naked next time and see how much weight that saves.
It's a 40 mile round trip, and I left with a full tank last time, so I used less than a gallon to get there. So, I had at least 10 gallons in the tank.
Thank you for the numbers Tom and Mike. Hmmm... Time to start weighing the stuff under the back seat. Spare distributor and carb, tool kit, gun and ammo, knives, crank, jack, all adds up apparently.
