The Ford Barn
-   -   Tudor overweight? (https://www.fordbarn.com/forum/showthread.php?t=139317)
P.S. 05-11-2014 05:28 PM
Tudor overweight?
I had to make a run to the dump today, and decided to use the Tudor so I could get it on the scale and find out what it weighs (for curiosity's sake and to calculate a total trailer weight if it was on a trailer).
Total weight? 2720 lbs.
That does include my 190 lbs., a full tank of gas, and the bag containing the jug of used motor oil and a small bag containing oil filter stuff.
I thought the Tudor was supposed to weigh just over 2100 lbs.??? What has caused my 31 to be so overweight?
1930artdeco 05-11-2014 05:49 PM
Re: Tudor overweight?
Paul,
I think you need to put the General on a diet:D
ronn 05-11-2014 06:18 PM
maybe the scale was out of wack...............
39topless 05-11-2014 06:31 PM
Maybe you should vacuum the car before it's weighed.
Jon 05-11-2014 06:49 PM
I've weighed my 29 Tudor twice. 2720 and 2640. Don't recall how much gas was in it either time, but that could account for the difference.
machine girl 05-11-2014 07:15 PM
maybe to much bondo! not really just having fun.
spdway1 05-11-2014 08:16 PM
You need to see if it is actual weight or gross ton. Most drive on dump, gravel pit and scrap yard scales are gross ton.
MrTube 05-11-2014 08:25 PM
I can't find anything on this online. What is "gross ton" and how does it differ from actual weight?
P.S. 05-11-2014 08:48 PM
Gee, thanks, Mike! Yea, The General is pretty obese. But, sorry M.G., no bondo in the car. Maybe vacuuming it out might make a difference... As long as the vacuum was strong enough to remove the nut behind the wheel.
The drive-on scale at the landfill measures in pounds. It's a digital scale and fairly accurate, I am told. However, I cannot guarantee that fact. A full tank of gas should weigh around 80 pounds.
So, is 2500 pounds (without driver) about right for a dead stock 31 Tudor Model A? Maybe Henry weighed them without wheels, gas, oil, water, etc.??
The whole point of this exercise is I am trying to do whatever possible to improve the fuel economy.
MrTube 05-11-2014 08:57 PM
How much does the water in the cooling system and oil in the engine, trans and differential weigh? I'm sure those were not included. What about your glass, is it original?
bikejunk 05-11-2014 09:00 PM
you= 190
gas and oil in engine and in jug say 100 lb. (gas is 6lb gallon)
spare tire and tube (spare tire did not come with car) say 40 lb
3 gallons of water say 30 lb. still =2,460 + about 250lb of tools under the rear seat :D= getting closer
mhsprecher 05-11-2014 09:06 PM
You know, we all gain weight as we age. Maybe your car did, too.
Tiny 05-11-2014 09:45 PM
You don't have old stale air in the tires do you. As it ages it absorbs atmosphere making it heavier. Try letting all the air out and refilling with fresh!! :D:D
P.S. 05-11-2014 09:48 PM
Ha ha!! You guys are just full of them tonight!
Maybe I need to fill the tires with helium...
Fred K-OR 05-11-2014 10:11 PM
May want to try a state highway scale just to compare weight from another scale. Here is Oregon you can drive right on and it tells you the weight.
Tiny 05-11-2014 10:26 PM
Helium could hurt!!!!
Tom Wesenberg 05-11-2014 10:27 PM
I thought the stated weight of a Tudor was just over 2400 pounds.
Mike V. Florida 05-12-2014 02:13 AM
1931 service letter, printed in The Restorer Magazine, Volume 33, Issue 1, Pages 30 - 33
Tudor Sedan 2375lbs
marc hildebrant 05-12-2014 09:26 AM
Were you in the car when it was on the scale ?
Marc
P.S. 05-12-2014 09:47 AM
Marc
Yes. I weigh just a little over 190 depending on what I'm wearing. Maybe I should drive over there naked next time and see how much weight that saves.
It's a 40 mile round trip, and I left with a full tank last time, so I used less than a gallon to get there. So, I had at least 10 gallons in the tank.
Thank you for the numbers Tom and Mike. Hmmm... Time to start weighing the stuff under the back seat. Spare distributor and carb, tool kit, gun and ammo, knives, crank, jack, all adds up apparently.
