Old 03-26-2014, 05:33 PM   #1
SUHRsc
SUHRsc's Avatar
Default 32 rear axle in Model-A rear?
The big green book lists 28-32 axle as interchangeable. I just would like to confirm before disassembling a '32 rear. Will the axle shafts interchange into a 30/31 Model-A rear without any problems?
I have a pretty galled up taper on both shafts on the A rear. One even seems to let the drum sit in too far as it had a shim on it when I initially took it apart.
Thanks for any help
Zach
-WANTED-
CYLINDER HEADS
77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS
SUHRsc is offline   Reply With Quote
Old 03-26-2014, 06:06 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 32 rear axle in Model-A rear?
There are 2 different 32 rears, the one using the same center banjo section has the same gears and axles as the A----if the area where the torque tube attaches is round like the A the in nerds are like A, if the area is scalloped like later V8 then the parts won't work
Old 03-26-2014, 06:07 PM   #3
Charlie Stephens
Most '32 axles will work fine in a Model A but I don't think the late '32 will work. You can identify the late rear end by scollops where the torque tube attaches to the center section.
Charlie Stephens
Old 03-26-2014, 07:37 PM   #4
Joe K
Joe K's Avatar
I seem to remember that a 32 scallop rear that came through my hands had a 4.11 gear ratio? Back then (pre overdrive & Mitchell) the 4.11 was what everyone wanted to get away from.
Can this be correct?
Joe K
Shudda kept the horse.
Old 03-26-2014, 07:41 PM   #5
SUHRsc
SUHRsc's Avatar
Thanks guys, should have mentioned this is an early '32 rear.
I'll strip it down tomorrow, hopefully the '32 axles look better!
Thanks
Zach
-WANTED-
CYLINDER HEADS
Old 03-28-2014, 12:09 PM   #6
Jim Brierley
the axle shafts and other parts interchange, the whole assembly will not as the spring mounts are different.
