I can't seem to figure out how to remove the spark advance and throttle levers. I don't see anything removable down at the spring end of the rods. Help!
On the lower end is an arm to hook the gas and spark rods to. There is a little pin that goes thru those arms. The pins have to come out. Hope I explained it properly.
Those pins that bill talked about are a PIA. I have found it tough to get them out without doing damage to the column paint, rods and levers.
Since i was replacing mine i whizzed off the rods above the levers at the bottom of collumn and went together with new rods, springs and levers. Last edited by Mitch//pa; 03-15-2014 at 10:22 AM. |
Bill in NJ is correct and then a lot of tapping on the arm and pulling to get the lever rods out or at least mine were very tight coming out. Hope this also helps.
Thanks for the help, guys! Understood.
Dave / Lincoln Nebraska |
1crosscut has the right solution. Those pins are very soft and will shear off when hammered as he describes. Then the control arms and springs will easily slide off, and you can pull the rods up through the upper column bushing, if the whole outfit isn't too rusty.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
+1 and that is the process that Les describes for removal in the book.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown Last edited by QGolden; 03-15-2014 at 08:29 PM. |
