Old 01-12-2014, 05:51 PM   #1
wbs
Default identify help
hello- see attached picture-is the foot pedal button below the clutch pedal original or was it something someone added?'28 phaeton. I can't find anything about it anywhere. thank you
wbs is offline   Reply With Quote
Old 01-12-2014, 05:57 PM   #2
700rpm
700rpm's Avatar
Default Re: identify help
Not original. Looks like a later dimmer switch.
Ray Horton, Portland, OR
Old 01-12-2014, 06:06 PM   #3
Patrick L.
Patrick L.'s Avatar
It does look like a dimmer switch. But, what does the rest of it look like ? And, what's it hooked to ?
Old 01-12-2014, 06:07 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Dimmer switch is my guess as well. Is it wired to anything?
Old 01-12-2014, 06:13 PM   #5
Pete
Could be dimmer, could be starter. Are there other non standard switches somewhere?
Maybe the original light switch bellied up and they rewired everything.
Old 01-13-2014, 08:41 AM   #6
wbs
thanks to all-all its wires are cut off-i think i'll just remove it
