Old 11-24-2013, 08:02 PM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Door windows.
On the driver side, my window will drift down while driving about an inch. If I have this same window down, it will drift up about an inch. What's happening and what do I need to do to correct it?
Thanks in advance.
Tom
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
Old 11-25-2013, 12:47 AM   #2
1967 Ford
Default Re: Door windows.
Mine does that also, but I usually have to drive the car more than an inch to have it happen.
(Sorry I had to throw that in....) I suspect a new window regulator would fix it. If there is a easier and cheaper way maybe one of our other members would know.
1967 Ford is offline   Reply With Quote
Old 11-25-2013, 08:58 AM   #3
jw hash
jw hash's Avatar
inside your winder on your window regulator there is a clutch spring that will not allow the window to move without turning the handle. I think you have a broken clutch spring. some of the regulators are easy to take apart and fix, and some are a pain to take apart.
jw hash is offline   Reply With Quote
Old 11-25-2013, 09:48 AM   #4
bobv
bobv's Avatar
Clean and oil worked for me.
bobv is offline   Reply With Quote
Old 11-25-2013, 07:07 PM   #5
Tom Cavallaro
If it is a broke clutch spring...is it a replaceable part, and who would have it..(part numbers) if possible.
Thanks so much.
Old 11-30-2013, 07:41 AM   #6
Tom Cavallaro
1930 coupe, I actually thought about that being a possibility, but the fact that it rides up when I have the window open dispels that, as many times as I have had this handle off. I can wind it up and down effortlessly but drifts one and a half inches in either direction.
Old 11-30-2013, 12:57 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I also think it's the clutch spring in the window regulator. The heavy counterweight spring must be in good order since the window can drift up or down, but the clutch lock spring isn't holding the shaft tight.
Old 11-30-2013, 01:14 PM   #8
John Kuhnast
Mount the handle such as the weight of the handle tends to hold it up when closed and down when open
John Kuhnast is offline   Reply With Quote
Old 11-30-2013, 03:57 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Chief's Tip# 119, would probably been, "Jist hang a Bull Durham Tobacco sack, full of gravel, on the window crank goody, to keep it up"!! Bill W.
"THE ASSISTANT GURU OF STUFF"
