Old 10-29-2013, 01:49 PM   #1
racer32
Default dumb '31 question.
Does the body have to come off to remove running board splash aprons?
racer32 is offline   Reply With Quote
Old 10-29-2013, 02:07 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: dumb '31 question.
Yes
Old 10-29-2013, 02:56 PM   #3
Mitch//pa
i just loosen the body bolts to lift up each side a couple inches for access. i usually do one side at a time... its not a big deal
Old 10-29-2013, 03:25 PM   #4
msmaron
msmaron's Avatar
NO not at all....All you have to do is remove the front, the A pillar and rear body bolts. stick a 2x4 or such under it and you can remove the RBoards...Good luck..
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 10-30-2013, 10:22 AM   #5
racer32
Thanks guys. Bolts are at cowl, A-pillar, and rear, then? I suppose I'll need to take loose the steering column drop, too. What else needs to be unhooked/disconnected?Car is Late '31 coupe.
Old 10-30-2013, 10:48 AM   #6
Ted in MN
You also need to pull the distributor to prevent stretching the armored ignition cable. I forgot and it broke the terminal box.
Ted in MN is offline   Reply With Quote
Old 10-30-2013, 11:10 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
And don't leave the head nut loose or you may have coolant in the oil.
Old 10-30-2013, 12:02 PM   #8
stouchton
stouchton's Avatar
Just wanted to says thanks to racer32 for bringing the topic up, and also to those who responded.
I had the exact same question, just remiss in asking.
I would gather anything from the firewall to the engine would need to be disconnected, Correct?
stouchton is offline   Reply With Quote
Old 10-30-2013, 09:07 PM   #9
racer32
Thanks!!!
