Old 05-19-2013, 02:17 PM   #1
Terry, NJ
Terry, NJ's Avatar
Default Inside wiring
I hope to start wiring my town sedan for the rear inside tight (Over the rear window) Is it ok to use the vinyl insulated wire. Yeah I know, "it's your car, use whatever you want!" I'm thinking of longevity. The braided cotton seems so fragile in comparison, And it seems like a huge job to fix it if it cracks or frays. Once it's in, I don't want to be taking it out, ever! What do you think? 100% no no? or it's OK to bend the restoration rules here?
Terry
Old 05-19-2013, 02:41 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Inside wiring
Out of sight/out of..................................
Paul in CT
Old 05-20-2013, 12:14 AM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
most reproduction braided wire has vinyl insulation inside it.
pat in Santa Cruz is offline   Reply With Quote
Old 05-20-2013, 12:28 AM   #4
Pete
No one will see it so use any AMERICAN made vinyl covered wire of proper gauge.
The foreign made stuff is oats that have been through the horse.
Personally I use teflon covered aircraft wire for all wiring. It won't melt or burn in case someone puts too big of a fuse in the circuit and you have trouble. The switch or the unit itself will burn and you can get at that a lot easier with a fire extinguisher.
Old 05-20-2013, 12:32 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
My understanding as well.
Old 05-20-2013, 08:40 AM   #6
Terry, NJ
Terry, NJ's Avatar
Thanks Guys! BTW where do you get 12 Ga (?) aircraft wire?
Terry
Old 05-20-2013, 11:26 AM   #7
Rock Hornbuckle
Rock Hornbuckle's Avatar
Terry
Terry is that 12 a typo?
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 05-20-2013, 01:58 PM   #8
1930artdeco
1930artdeco's Avatar
Aircraft and car wire are the same if made in the usa. But, if you want aircraft then go near any airport where they fix aircraft. Usually one of the larger ones and tell then what you need.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-20-2013, 03:27 PM   #9
MikeK
MikeK's Avatar
Aircraft wire by the foot: LINK
MikeK is offline   Reply With Quote
Old 05-20-2013, 03:46 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Terry,
If you want "FOREVER" wire, run it through a long vacuum hose for protection. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-20-2013, 04:00 PM   #11
Pete
Here's another place that has Teflon covered aircraft wire, both new and surplus.
The surplus is pretty cheap.
http://www.dexknows.com/business_pro...lty_co-b309040
Old 05-20-2013, 04:03 PM   #12
BILL WILLIAMSON
But a FOOT won't be long enough! WHY do they cut it up???Buster T.
Old 05-20-2013, 05:06 PM   #13
Mitch//pa
they are selling off the wiring from the space shuttles thats what i would use
Old 05-20-2013, 05:12 PM   #14
BILL WILLIAMSON
Was it made in China, or Tawan?? and is it longer than 12" (That's A foot.) Buster T.
Old 05-20-2013, 05:44 PM   #15
Mitch//pa
You can get any length you want and it's made from super alloy perfect for a model A dome light
Old 05-20-2013, 07:30 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
12 gauge is overkill as far as the size needed for the third brake light.
I bought elevator wiring from the recycling yard about 10 years ago. It's quality wiring and very long and flexible. I don't know if the elevator was being torn down, or if the wiring just needs to be replaced every so often due to a law.
Old 05-20-2013, 07:35 PM   #17
Terry, NJ
Terry, NJ's Avatar
Nope, Not at the time. Just a little thought about it and I realised that 12 ga was a little heavy for a 3W light. Another case of typing it out before engaging brain! And Mitch... Got me all confused with that stuff about space shuttle wire! And Bill had me splicing and taping 12" sections.... Gollleee! A person can't think with all that going on. Time to feed the Gerbil!
Terry
Old 05-20-2013, 10:46 PM   #18
Tom Wesenberg
Terry
I hope you're feeding it to the cat!
