The Ford Barn
-   -   Inside wiring (https://www.fordbarn.com/forum/showthread.php?t=106594)
Terry, NJ 05-19-2013 02:17 PM
Inside wiring
I hope to start wiring my town sedan for the rear inside tight (Over the rear window) Is it ok to use the vinyl insulated wire. Yeah I know, "it's your car, use whatever you want!" I'm thinking of longevity. The braided cotton seems so fragile in comparison, And it seems like a huge job to fix it if it cracks or frays. Once it's in, I don't want to be taking it out, ever! What do you think? 100% no no? or it's OK to bend the restoration rules here?
Terry
1931 flamingo 05-19-2013 02:41 PM
Re: Inside wiring
Out of sight/out of..................................
Paul in CT
pat in Santa Cruz 05-20-2013 12:14 AM
Re: Inside wiring
most reproduction braided wire has vinyl insulation inside it.
Pete 05-20-2013 12:28 AM
Re: Inside wiring
No one will see it so use any AMERICAN made vinyl covered wire of proper gauge.
The foreign made stuff is oats that have been through the horse.
Personally I use teflon covered aircraft wire for all wiring. It won't melt or burn in case someone puts too big of a fuse in the circuit and you have trouble. The switch or the unit itself will burn and you can get at that a lot easier with a fire extinguisher.
Mike V. Florida 05-20-2013 12:32 AM
Re: Inside wiring
My understanding as well.
Terry, NJ 05-20-2013 08:40 AM
Re: Inside wiring
Thanks Guys! BTW where do you get 12 Ga (?) aircraft wire?
Terry
Rock Hornbuckle 05-20-2013 11:26 AM
Re: Inside wiring
Terry
Terry is that 12 a typo?:confused:
1930artdeco 05-20-2013 01:58 PM
Re: Inside wiring
Aircraft and car wire are the same if made in the usa. But, if you want aircraft then go near any airport where they fix aircraft. Usually one of the larger ones and tell then what you need.
Mike
MikeK 05-20-2013 03:27 PM
Re: Inside wiring
Aircraft wire by the foot: LINK
BILL WILLIAMSON 05-20-2013 03:46 PM
Re: Inside wiring
Terry,
If you want "FOREVER" wire, run it through a long vacuum hose for protection. Bill W.
Pete 05-20-2013 04:00 PM
Re: Inside wiring
Here's another place that has Teflon covered aircraft wire, both new and surplus.
The surplus is pretty cheap.
http://www.dexknows.com/business_pro...lty_co-b309040
BILL WILLIAMSON 05-20-2013 04:03 PM
Re: Inside wiring
But a FOOT won't be long enough!:eek: WHY do they cut it up???Buster T.:cool:
Mitch//pa 05-20-2013 05:06 PM
Re: Inside wiring
they are selling off the wiring from the space shuttles thats what i would use
BILL WILLIAMSON 05-20-2013 05:12 PM
Re: Inside wiring
Was it made in China, or Tawan??:confused: and is it longer than 12":confused: (That's A foot.) Buster T.:cool:
Mitch//pa 05-20-2013 05:44 PM
Re: Inside wiring
You can get any length you want and it's made from super alloy perfect for a model A dome light
Tom Wesenberg 05-20-2013 07:30 PM
Re: Inside wiring
12 gauge is overkill as far as the size needed for the third brake light.
I bought elevator wiring from the recycling yard about 10 years ago. It's quality wiring and very long and flexible. I don't know if the elevator was being torn down, or if the wiring just needs to be replaced every so often due to a law.
Terry, NJ 05-20-2013 07:35 PM
Re: Inside wiring
Nope, Not at the time. Just a little thought about it and I realised that 12 ga was a little heavy for a 3W light. Another case of typing it out before engaging brain! And Mitch... Got me all confused with that stuff about space shuttle wire! And Bill had me splicing and taping 12" sections.... Gollleee! A person can't think with all that going on. Time to feed the Gerbil!
Terry
Tom Wesenberg 05-20-2013 10:46 PM
Re: Inside wiring
Terry
I hope you're feeding it to the cat!:D
