Old 04-29-2013, 11:43 PM   #1
Vern
Vern's Avatar
Default New use for old Camshafts
I found a neat way to use some old camshafts; as table legs. The top is a piece of the eucalyptus tree we took out last spring, about 4" thick. It weighs a bunch, but it will support my favorite beverage.
Vern is offline   Reply With Quote
Old 04-30-2013, 01:09 AM   #2
PC/SR
Default Re: New use for old Camshafts
Neat use for old cams but how did you cut the wood? I dulled and burned a chainsaw trying to cut eucalyptsus tree.
PC/SR is offline   Reply With Quote
Old 04-30-2013, 06:05 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
PC, look into buying a Carbide tipped chain. Saw a man cutting 6" ROOTS, down in the dirt, even, with one. For homeowner use, they'll almost last forever! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-30-2013, 07:46 PM   #4
dave in australia
The profile of the teeth for cutting eucalyptus is different to the profile for cutting other woods. It also has to be sharpened at certain angles to prevent quick blunting.
dave in australia is offline   Reply With Quote
Old 05-01-2013, 09:07 AM   #5
Bill in SoCal
Bill in SoCal's Avatar
It cuts real easy when it is green, and becomes rock hard when it dries. Bill
Bill in SoCal is offline   Reply With Quote
Old 04-30-2013, 08:50 AM   #6
Kirby1374
Kirby1374's Avatar
I cut through one quite easily........ just ask my mother-in-law :-)
Kirby1374 is offline   Reply With Quote
Old 04-30-2013, 01:45 PM   #7
Pete
I drilled a cam lengthwise years ago and made a lamp out of it.
Old 04-30-2013, 03:59 PM   #8
1oldtimer
1oldtimer's Avatar
I have 3 cams and was going to make an aluminum boomerang shaped table years ago........but it's still waiting. I have a carb lamp, 2 paint gun lamps and a parking meter lamp.....auto parts are the best furniture.
1oldtimer is offline   Reply With Quote
Old 05-01-2013, 04:06 PM   #9
Mikeinnj
Mikeinnj's Avatar
And obviously a very understanding wife.....
Mikeinnj is offline   Reply With Quote
Old 05-01-2013, 09:01 AM   #10
Richard Lorenz
To 1oldtimer above: I have an Edmund and Jones 1913 era acetylene headlight. Is this the sort of thing that you referred to as your "carb lamp"? I would like to know how you made the lamp.
Richard Lorenz is offline   Reply With Quote
Old 05-01-2013, 11:40 AM   #11
1oldtimer
1oldtimer's Avatar
It's an actual carb, a Rochester 2 jet that was junk. I bought a lamp kit from Builders Emporium (it was that long ago) and found some wood for a base. Did the same thing with my old paint guns.
