New use for old Camshafts I found a neat way to use some old camshafts; as table legs. The top is a piece of the eucalyptus tree we took out last spring, about 4" thick. It weighs a bunch, but it will support my favorite beverage.
Re: New use for old Camshafts Neat use for old cams but how did you cut the wood? I dulled and burned a chainsaw trying to cut eucalyptsus tree.
Re: New use for old Camshafts Quote:
Re: New use for old Camshafts I cut through one quite easily........ just ask my mother-in-law :-)
Re: New use for old Camshafts I drilled a cam lengthwise years ago and made a lamp out of it.
Re: New use for old Camshafts I have 3 cams and was going to make an aluminum boomerang shaped table years ago........but it's still waiting. I have a carb lamp, 2 paint gun lamps and a parking meter lamp.....auto parts are the best furniture.
Re: New use for old Camshafts To 1oldtimer above: I have an Edmund and Jones 1913 era acetylene headlight. Is this the sort of thing that you referred to as your "carb lamp"? I would like to know how you made the lamp.
