My tailpipe has a bad rattle. It drive me bonkers. I know they have to be a little loose for heat expansion but how much? Is there something to be inserted between the rear clamp and pipe? Appreciate all info on this Thanks RAY
When your wife is not looking take one of her new silicone rubber spatulas and cut off a strip to use in the clamp. It will take the heat and be rubbery to hold tight the pipe and allow for expansion.
Ray64, I had a exhaust ring drop into the exhaust pipe while changing gasket. A rattle I had until I changed the exhaust pipe finding not one but two rings.
DRHAAG |
Are you sure its the clamp? A loose baffle will cause quite an irritating rattle... Had one on my skidloader, after a couple years it wore through the outside case of the muffler. As I could then see where it was, I took the muffler off and welded the baffle from the outside, filling the wear hole at the same time. Ran for years like that, no more rattle.
Do a search . There is a fellow on here that is giving away insulation material to put on the inside of the clamp which will solve the rattle problem . Send him a self addressed envelop and he will mail you back some insulation material . He mailed me some .
And I thought that I was the only one that dropped a gland into the muffler. I was going to post that if you have the pipe disconnected, you should plug it with a rag.
If the rattle is the rear clamp, I insert a strip of welding glove sleeve.
I made a rubber insulated hanger which installs in the original frame hole as the existing tailpipe clamp and holds the pipe at the height as original. NO MORE RATTLES!!!
AL in NY |
In the case of SS tail pipe , the pipe has to lay in the clamp loose so it can expand .
