gen not in line with crank pulley??
www.whidbeymodelaclub.com |
Any chance you have a timing cover from a 1933-34? They move the generator back to allow for the slope of the radiator in the later vehicles. You can see a picture of one in my old ad: https://www.fordbarn.com/forum/showth...ens#post475242
How is the alignment at the water pump and is it a model A pump? If you have the correct 4 bolt Model A water pump and it lines up with the generator then the problem is with the front pulley. Any chance something is keeping the pulley from going all of the way in? Charlie Stephens Last edited by Charlie Stephens; 01-27-2013 at 07:02 PM. |
#3 | |
![]() Quote:
I just used a dividers to measure the center of the V on my crank pulley to the front timing cover lip for the front motor mount and I get 1 3/32". All 3 of my pulleys line up nicely.
What did you do to get in this predicament? In otherwords-just putting back together, replaced generator or ???????
What was the last thing you did before the problem appeared? My guess would be that there is something keeping the front pulley from going all the way in. Do you have a two piece pulley?
Charlie Stephens |
do you have the generator mounting bracket on backwards? It can go eather way buy only line up the correct way...just a thought
#9 | |
![]() Quote:
#10 | |
![]() Quote:
#11 | |
![]() Quote:
gary...doing ok at this end buddy....love ur trucks.....how long have you been driving this with it misaligned? It has to be eather the front cover or the mounting brackets on the generator. If soneone has rebuilt the generator it is easy to get the bracket on the wrong way.....let us know what you find out...the best to ya bud..
#13 |
Back to the picture in #1, is the pulley not lined up, or is the steel yardstick running crooked due to a crank pulley wobble? Turn the crank 180* and see if the yardstick still shows the same gap to the generator. Also measure as I did in #4 if the pulley doesn't show wobble. If the pulley shows wobble then that needs to be corrected first.
BTW, my temporary engine also has a two piece pulley, and that's why I gave a measurement from the center of the V rather than the easier to measure rear edge of the crank pulley. |
#14 |
#15 | |
![]() Quote:
www.whidbeymodelaclub.com Last edited by Gary WA; 01-28-2013 at 07:21 PM. |
#16 | |
![]() Quote:
#17 | |
![]() Quote:
#18 |
![]() Hi Gary Could it be some of the part's got switch as shown in the April 30 service bulletin's...different pulley with the different armature shalf's ??? Greg out West |
#19 |
If you stand right in line with the V belt, how does it look?
I'm still wondering if the crank pulley has a bend or something keeping it from seating fully? |
#20 |
Removed the pulley compared to others I have looks OK. the belt does wobble and you do notice the offset. Here are some more pics. rotated 180 same look.
