Old 01-06-2013, 12:32 PM   #1
firechief5215
firechief5215's Avatar
Default Rear end noise
I have a early 1928 aa, When i let of the clutch i hear a clunk noise that apears to be comming from the rear, I dont hear any grinding noise and the rear is full of grease, any ideas what this may be and is it a hard repair for the average mechanic Thanks you Billy
firechief5215 is offline   Reply With Quote
Old 01-06-2013, 12:51 PM   #2
Bob C
Default Re: Rear end noise
My guess is a bad u-joint, worn coupling between the drive shaft and worm gear, or excessive play
in the gears.
Bob
Old 01-06-2013, 02:48 PM   #3
Jim Brierley
Could also be a loose axle nut?
Old 01-06-2013, 03:47 PM   #4
Marco Tahtaras
Marco Tahtaras's Avatar
Ditto. Years ago a buddy came by with his Coupe for help chasing a "clunk". The noise traveled all the way up to the trans and turned out to be a loose axle nut with the hub clunking for and aft against the keyway.
In this case we held the brake on and partially engaged the clutch and got the clunk but would only do it once. It would then do the same in reverse only once until we reversed direction once again removing the slop in that direction.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-06-2013, 05:30 PM   #5
firechief5215
Thank you for your help , Now i have a starting point i will look into it further , Im sure i will be back with more on this Thank You Billy.
