Hey Guys,
I'm bolting my front crossmember onto my car since I'm not set up to do the correct riveting. I'm using grade 8 bolts with nylon locknuts in every hole where there would have been a rivet (14 total). My question is......Is there anything I should or shouldn't do when bolting my crossmember in? Thought I'd ask y'all since i couldn't find nothing in Andrew's book or by using the search function. Thanks in advance, Josh
"The Assistant to the Assistant of The Guru of Stuff" |
My advice would be to find a shop to rivet it in.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Before tightening I would ck and double ck the frame for "squareness". I, personally would use regularnuts w/lockwashers WITH loctite. JMO
Paul in CT |
#4 | |
![]() Quote:
For what it's worth, I think your way is dandy and stronger than rivets, I'd do the same with a drop of blue Loctite. Loctite just makes me feel GOOD! ![]() If I were ever to build another car for dependability, I would replace EVERY castrated nut with self locking nuts, and, OH YES, that little drop of blue LOCTITE! Bill W.
You couldn't go wrong with loctite, lock nut, and lock washer if you are bolting it in.
Cowtown A's |
When I pull the engine from my 29 coupe I am going to have to replace the front cross member also. I plan to bolt it back in.
#7 | |
![]() Quote:
#8 | |
![]() Quote:
![]() Bill W.
A friend has a bolted in front crossmember in his '32 Ford and is happy with it. I believe he has counter sunk head bolts on top that have an Allen head socket.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
As mentioned, the top six must be countersunk. This is required for clearance and Allen head type screws are all you can get that aren't junk,
If done well it will last forever. The only side effect should be subtle squeaks and such that most folks think are normal for a model A. They won't show up for awhile.
http://www.abarnyard.com/ |
That's what I was wondering 'bout!
So to muddy up the water a bit, why the need for Loctite? Over time the frame will twist & flex, and just as Marco has said, there will be subtile squeaks ...but why the squeaks? The obvious answer is because the bolts are loose but is it because the nuts backed off, or because the fastener has stretched? My thoughts are that the fastener has more likely stretched but I would like to hear your thoughts.
#13 | |
![]() Quote:
#14 |
You probably won't be driving this car every day as it was designed to do, but there's a reason why they engineered rivets in these cars, and I would stick with the original intent if you can. Maybe find someone that can put rivets in for you.
Tommy- |
#15 |
I did one years ago using flat head Allen socket screws,I believe were fine thread along with split l'washers and nuts either 5/16 or 3/8 (don't remember). These are the black oxide strong machine screws and never had a problem with loosening up.
#16 |
Typically rivets are best suited for shearing loads applications over tension loads. High strength bolts are better at tension loads over rivets. Any joint looseness could be attributed to the nut coming loose or wear on the bolt shaft due to shearing forces from the frame flexing. I would think grade 8 fasteners could replace the frame rivets.
#17 |
Bolts will never replace rivets. When a rivet is installed, the rivet swells in the hole creating an interference fit. When a bolt is torqued, the stretch actually cause a slight reduction in cross sectional area. That said, the correct bolts will work. Use a fine thread bolt. For a given torque, it has more clamping force and a larger cross section at the minor diameter than a coarse thread bolt. Also, try to find a bolt that has an unthreaded portion to go in the hole. You may have to buy longer bolts and cut them to length to get the correct unthreaded portion length.
Bob |
#18 |
Worry, worry, worry! Most of the twisting & flexing will be absorbed in the length of the frame rails.
Why rivets originally: Probably faster and cheaper, and I doubt they were grade 8. Don't forget, a number of years back, Ford trucks had rivet problems in the frames causing all kinds of horrible popping and groaning sounds. You can re-tighten bolts, if they ever loosened, but it would be a "BEARCAT" to re-tighten rivets. Yes, I know it's not PROPER, but sometimes we have to be practical. Bill W. Oh! and why Loctite, why not??
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 03-09-2012 at 11:08 AM. |
#19 | |
![]() Quote:
Also, to re-tighten those bolts, how do you gain access to the top of the bolt to hold it while you attempt to tighten the nut when the fender is covering the bolt head? Maybe I am wrong but it don't seem too practical to remove the headlights & wiring, the headlight bar, radiator apron and the fenders just to be able to put a wrench on that bolt head!! Maybe I am overlooking something and if so, I apologize in advance for my ignorance in this. . |
#20 | |
![]() Quote:
