This eBay auction is for a steering column mount for a rat rod I suppose 390347313077. Got a real good chuckle over this one.....
That's a good one allright!
I wonder what happens the first time you grab the steering wheel to pull yourself into the vehicle? |
Shesh! I'm not sure why there needs to be a floor mount for a steering column. It is mounted to the frame, and then secured again at the top.
Also, this thing is ugly as sin. Why wouldn't this be a welded/fabricated piece? What a cheap piece of junk. ![]()
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
if you are using a GM column in a street rod then this would work well. Carpet would cover this up.
#5 | |
![]() Quote:
![]() Also, this would be the only use for a muffler clamp on a rat rod anyway. |
When it was common to put a late model steering colum in your street rod this was/is the ticket. It gets completly hidden and you must support the lower column since you add in u-joints to adapt steering. For the 1-800 street rod guys this solved a lot of support and angle problems, particularly when a first time builder may not have a welder or the fabrication skills. I wish I had made the originals, there has been a lot of those sold. Wouldn't be the first time a part got re purposed. As for the quality of it, well... I wouldn't put that one in my car. Rat Rods - don't even get me started. |
