Old 03-26-2025, 05:03 PM   #1
elmo771
Default 1956 engine mounts
Is there any difference on a 1956 6 cylinder and a v-8 cylinder frame mount cradle
elmo771 is offline   Reply With Quote
Old 03-26-2025, 09:09 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 1956 engine mounts
"Full-sized cars"? . . or something else?
Old 03-27-2025, 07:03 AM   #3
elmo771
1956 Customline, the frame piece with the 2 holes for the motor mounts.
Old 03-27-2025, 08:24 AM   #4
KULTULZ
KULTULZ's Avatar
Arrow Re: 1956 engine mounts
The 1955-56 FORD CROSS-MEMBER ENGINE FRAME MOUNTS are the same.
KULTULZ is offline   Reply With Quote
Old 03-27-2025, 09:31 AM   #5
56sedandelivery
56sedandelivery's Avatar
55-58 6 cylinder B7A 6038-B
54-58 Y Block B7A 6038-A
56sedandelivery is offline   Reply With Quote
Old 03-27-2025, 11:27 AM   #6
KULTULZ
KULTULZ's Avatar
Question Re: 1956 engine mounts
Now are we describing the flange mounting brackets welded to the engine mounting cross-member or the actual insulators?
Old 03-28-2025, 08:06 AM   #7
elmo771
The flange mounting brackets on the crossmember
Old 03-28-2025, 09:21 AM   #8
KULTULZ
KULTULZ's Avatar
The actual flange(s) itself is the same as there was no separate 6CYL or 8CYL frame released. The cross-member itself is a part of the complete frame assy.
The difference is in the insulators and 6CYL block mounting brackets on the 6CYL.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
Old 03-28-2025, 09:06 AM   #9
56sedandelivery
I would think they are the same with the engine mounts being the difference.
Mine originally came with a 6 but now has a V8. But my mounts are custom made as is non original V8.
Old 03-28-2025, 09:30 AM   #10
elmo771
Thanks looking to do a v-8 converision
Old 03-28-2025, 09:51 AM   #11
KULTULZ
KULTULZ's Avatar
You are more than welcome
GOOD LUCK with the conversion.
