1956 engine mounts Is there any difference on a 1956 6 cylinder and a v-8 cylinder frame mount cradle
Re: 1956 engine mounts "Full-sized cars"? . . or something else?
Re: 1956 engine mounts 1956 Customline, the frame piece with the 2 holes for the motor mounts.
Re: 1956 engine mounts 2 Attachment(s)
The 1955-56 FORD CROSS-MEMBER ENGINE FRAME MOUNTS are the same.
Re: 1956 engine mounts 55-58 6 cylinder B7A 6038-B
54-58 Y Block B7A 6038-A |
Re: 1956 engine mounts 1 Attachment(s)
Now are we describing the flange mounting brackets welded to the engine mounting cross-member or the actual insulators?
Re: 1956 engine mounts The flange mounting brackets on the crossmember
Re: 1956 engine mounts I would think they are the same with the engine mounts being the difference.
Mine originally came with a 6 but now has a V8. But my mounts are custom made as is non original V8. |
Re: 1956 engine mounts Quote:
The difference is in the insulators and 6CYL block mounting brackets on the 6CYL. |
Re: 1956 engine mounts Thanks looking to do a v-8 converision
Re: 1956 engine mounts You are more than welcome
GOOD LUCK with the conversion. |
