Old 12-29-2024, 04:28 PM   #1
Ggmac
Default Identifying LZ gears
How can I tell a set of LZ gears from regular Ford sets ? One of my spare transmissions supposedly has them .
Thanks , Gary
Old 12-29-2024, 04:45 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Identifying LZ gears
What is the tooth count on the large front gear on the cluster gear? LZ’s were either 25 or 26 teeth.
Zeke3 is offline   Reply With Quote
Old 12-29-2024, 05:13 PM   #3
Ggmac
What are normal a Ford gear count ?
Old 12-29-2024, 05:40 PM   #4
cas3
There are lots of gears. Gotta go to Mac VP's sight and study the tooth count and application charts
Old 12-29-2024, 07:56 PM   #5
Will Kimble
Common main drive gear tooth count is 15 or 16. LZ is 18 or 19. I use the oil hole for reference and can count this pretty quick. Common cluster is 28 or 29 (big end) and LZ is 25 or 26. Harder to count in a dirty, oily transmission. Rule of 44: 15/29, 16/28, 18/26, 19/25.
Will Kimble is offline   Reply With Quote
Old 12-29-2024, 08:02 PM   #6
rotorwrench
rotorwrench's Avatar
The standard gears are 16/28 if I remember correctly.
Old 12-29-2024, 09:53 PM   #7
Tim Ayers
Put a grease pencil mark on one of the teeth of large gear on the lower cluster. Count as you rotate. If it is 25 or 26, you have an LZ gear set.
Old 12-29-2024, 09:53 PM   #8
Tim Ayers
Correct
Old 12-30-2024, 05:47 AM   #9
Ggmac
Thanks guys . I forgot about Mac s book , sitting on the shelf .
Old 12-30-2024, 07:09 AM   #10
glennpm
glennpm's Avatar
From my notes. I have this set in my '32 and they're great
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 12-31-2024, 08:42 AM   #11
glennpm
glennpm's Avatar
I posted RPM versus road speed for my setup here:
https://www.fordbarn.com/forum/showp...6&postcount=23
Rumble Seat's Notes
