Old 12-31-2023, 05:16 AM   #1
jayg48anglia
jayg48anglia's Avatar
Default Miller Hi Speed Head Installation.
I have a well built A motor in my 29 and I am considering converting to a Miller head. I am looking for feedback from owners at this point and not the company. How was the install and were there any problems along the way? Are you satisfied with the performance and quality of the parts. THX. Jay
jayg48anglia is online now   Reply With Quote
Old 12-31-2023, 01:35 PM   #2
johnneilson
Default Re: Miller Hi Speed Head Installation.
Jay
I have built a few motors with the Miller head
The quality is top notch and machine work superb
Depending on your setup you may need a fuel pump and the exhaust will be different as the ports are about 3” higher
And yes I have one on a coop sn 002 if that has any weight
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 12-31-2023, 01:40 PM   #3
Jim Brierley
I have installed an early Miller, not a modern aluminum one, but they are externally the same. The hardest part is removing the stock studs, the rest is an easy bolt on. The new Miller kit is very complete, and is therefor easy to install. They perform very well, but do require a lot of spark advance in order to get maximum performance. The stock cam can be used but an OHV grind is best.
Old 12-31-2023, 03:44 PM   #4
motordr
You will have to relocate the terminal box to inside the firewall. Also if using sock exhaust manifold you have an interferance at the rear. Headers or modify the firewall slightly.
motordr is offline   Reply With Quote
Old 01-01-2024, 03:29 AM   #5
jayg48anglia
So the install is a bolt on with no machine work? What is everyone using for a carb/intake setup?
Old 01-01-2024, 11:17 AM   #6
AzBob
Just wondering, does the Miller OHV setup only make gains in HP and torque in the higher rpm ranges or does the Miller OHV also improve lower end torque response above say an available 6:1 or 6.5:1 flat head?
Am thinking for street and touring use, the flat head may have an advantage.
AzBob is offline   Reply With Quote
Old 01-01-2024, 11:38 AM   #7
jayg48anglia
AzBob, If you go on the Miller site they have a section with dyno charts if that will help you out.
Old 01-01-2024, 11:51 AM   #8
johnneilson
Jay,
The original Cragar head was a conversion done to increase capacity of the AA trucks, it was a true bolt on conversion.
You are now asking about performance gains and modifications, a much different question.
Jim Brierley has a book out, 4-Bangers and Me! Not too expensive and gives a really good basic understanding of the modifications done over the years.
Back to your question about carbs and manifolds, it depends on your application and intended usage. I prefer a single carb on a street car, Holley 94/2100 or a Stromberg 97.
Best, John
Old 01-02-2024, 12:41 PM   #9
Jim Brierley
Any manifold made for the Model A will fit the Miller. Like John, I prefer a single carb. See the addendum in my book for details.
Old 01-04-2024, 04:03 PM   #10
Jordan
Jordan's Avatar
My brother has two, he love them. When we drove to Colorado for the High Country Tour this summer, 4 of the 6 cars had the new Millers under the hood on new Burtz motors.
Cowtown A's
Jordan is offline   Reply With Quote
