Old 10-14-2023, 01:48 PM   #1
cars2cool
Default Assembly plant help decipher
I have tried to look up the assembly plant information of my Model A pickup, by the frame rail number it is a September 22 1930 engine build date. On the body cross member the number is either a "B" or an "8" located in the center of the cross member, and closer to the drivers right heel is the number 4522. It is a round speedometer closed cab pickup. The pickup was bought by the previous owner in the late 50's or early 60's in eastern South Dakota while he was in college. The painted letters on the hood were for a plumbing business. My dad transferred the title in July 1963 to his name. Any help is appreciated.
Last edited by cars2cool; 10-14-2023 at 02:40 PM. Reason: Add information, spelling correction
cars2cool is offline   Reply With Quote
Old 10-14-2023, 02:15 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Assembly plant help decipher
You need to buy these two Great Books!! Thanks to Steve!!
www.whidbeymodelaclub.com
Old 10-14-2023, 02:39 PM   #3
cars2cool
Gary WA thanks, I visited his web site this morning and did not come up with a definitive answer to my question. He has done extensive research that is for sure.
Old 10-14-2023, 03:33 PM   #4
Gary WA
Gary WA's Avatar
what year is your pick up?
Old 10-15-2023, 09:54 AM   #5
cars2cool
Gary WA - The truck is titled as a 1931, it is a closed cab (not a steel roof) and the narrow wood floor box like the earlier pickups. I think the reasoning behind the 1931 title year is that is when it was first sold.
Old 10-14-2023, 03:58 PM   #6
WTSHNN
WTSHNN's Avatar
Try page 14
http://www.plucks329s.org/pdf/studie...ND%20CODES.pdf
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 10-14-2023, 04:16 PM   #7
rotorwrench
rotorwrench's Avatar
Briggs and Murray built and marked some of their bodies. Budd made a lot of the closed cabs under contract to Ford. Subcontracted bodies and cabs were sent out complete to the various home and branch plants for final assembly. Ford's branch assembly plants as well as the Rouge didn't do much toward marking where all their products were assembled. If a person was fortunate enough to know what dealer the vehicle was originally sold from then it would likely be from the nearest branch plant. Ford didn't really start stamping final assembly information on till the late 40s. Some branch plants had more capability than others. The closest branch plant to South Dakota was likely the Demoine, Iowa facility. There was already a lot of water under the bridge by the late 1950s.
Old 10-15-2023, 09:56 AM   #8
cars2cool
When did the plant in Omaha Ne. start operation? Did Budd or Briggs make the non steel roof cabs? I wonder if that "B" or "8" is a B for Budd or Briggs.
Old 10-15-2023, 11:52 AM   #9
Gary WA
Gary WA's Avatar
Plant dates May 10 1920 closed March 1932.Thanks to Steve Plucker
Old 10-15-2023, 04:40 PM   #10
rotorwrench
Budd made both pieces and complete cabs depending on time frame. The solid top cabs were likely completed by Budd. They mere made very close to the end of production for the model A. Ford sold a lot of trucks and pickups but they were still in the limited category much the same as all the Fordors. Production slowed a lot in 1931 as the depression got worse.
Old 10-15-2023, 06:59 PM   #11
Keith True
Keith True's Avatar
Is it an indented or flat firewall cab? Sounds like a June or earlier truck.Firewall will narrow it down a little more.It could be a 30,titles are manmade pieces of paper that can say anything.
Old 10-16-2023, 03:55 PM   #12
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I have a 31 wide bed pickup. Does not have a steel roof or indented firewall, and it has an oval speedometer. Might be all correct or it could be a frankentruck.
Ivan in southeast va. is offline   Reply With Quote
