Old 03-18-2023, 11:55 AM   #1
kurt v
Default carb 94 power valves
why two valves included in kits, one short and a long one , i use the short one, what carb takes the long valve and why ?
thanks kurt
kurt v is offline   Reply With Quote
Old 03-18-2023, 12:08 PM   #2
marko39
Default Re: carb 94 power valves
I think the second one is a spark valve for the later carbs.
marko39 is offline   Reply With Quote
Old 03-18-2023, 03:05 PM   #3
flatjack9
flatjack9's Avatar
Yes
Old 03-18-2023, 06:10 PM   #4
scicala
scicala's Avatar
The kits are usually made to work on all carbs from '39 through '56 Fords.
The spark valves were used from'54 through '56.
Make sure you install the correct one, since they are spring loaded in opposite directions.
Sal
scicala is offline   Reply With Quote
Old 03-18-2023, 06:14 PM   #5
scicala
scicala's Avatar
thanks kurt
Also, if you used the short one for the power valve, I'm pretty sure the short one is the spark valve and won't work. Use the one that's spring loaded in the same direction as the one you removed to be sure.
Sal
Old 03-18-2023, 07:21 PM   #6
Ken/Alabama
Ken/Alabama's Avatar
Speaking of power valves, I need Charlie’s contact. I bought some from him a couple years ago and I used my last one today.
Old 03-18-2023, 09:13 PM   #7
JayChicago
JayChicago's Avatar
Charlie Schwendler
Orchard Park, N.Y.
716 662-9159
Old 03-19-2023, 10:02 AM   #8
kurt v
Ken i just got some from daytona carb.
kurt
