The Ford Barn
-   -   carb 94 power valves (https://www.fordbarn.com/forum/showthread.php?t=324541)
kurt v 03-18-2023 11:55 AM
why two valves included in kits, one short and a long one , i use the short one, what carb takes the long valve and why ?
thanks kurt
marko39 03-18-2023 12:08 PM
Re: carb 94 power valves
I think the second one is a spark valve for the later carbs.
flatjack9 03-18-2023 03:05 PM
Yes
scicala 03-18-2023 06:10 PM
The kits are usually made to work on all carbs from '39 through '56 Fords.
The spark valves were used from'54 through '56.
Make sure you install the correct one, since they are spring loaded in opposite directions.
Sal
scicala 03-18-2023 06:14 PM
thanks kurt
Also, if you used the short one for the power valve, I'm pretty sure the short one is the spark valve and won't work. Use the one that's spring loaded in the same direction as the one you removed to be sure.
Sal
Ken/Alabama 03-18-2023 07:21 PM
Speaking of power valves, I need Charlie’s contact. I bought some from him a couple years ago and I used my last one today.
JayChicago 03-18-2023 09:13 PM
Charlie Schwendler
Orchard Park, N.Y.
716 662-9159
kurt v 03-19-2023 10:02 AM
Ken i just got some from daytona carb.
kurt
