Is there a better method for loading oil into the differential without trying to squeeze a bottle of 600w oil into a fill hole that's almost horizontal?
Thanks in advance for your comments. |
Sure,stick a piece of fuel hose on the squirter end,stick it in the hole,hold the bottle vertical,and squeeze it.
Suction gun is an easy way. Get yourself one from harbor freight. unscrew the guns lid and fill it up, shove the hose into the fill port and push on the plunger. That's how i do it
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
I found that if you cut the tip on the squeeze bottle pretty short so the opening is large it doesn't take a whole lot of time and effort to get it in.
You could warm the oil in a pan of boiling water to make it flow easier.
Dave / Lincoln Nebraska |
Little hand pumps and electric pumps are used to fill the fuel tanks of model airplanes. I wonder if one of those would work. There are big sized pumps for larger airplanes.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
How about a turkey baster from the 99cent store?
Charlie Stephens |
55 years ago I found my rearend was low of fluid, got some black thick 600w in a quart metal can. It was in the fall a cool, how do I get it in there, found a long hose a funnel and warmed the can on the boiler. Stuck one end in the diff, ran the hose up to the spare tire added the funnel. Poured the warmed black 600w into the funnel and then waited for ever for it to flow down into the differential. Dumb teenager had more time than money LOL
