The Ford Barn
-   -   Oil Addition to Differential (https://www.fordbarn.com/forum/showthread.php?t=346219)
Colonel 02-04-2025 05:29 PM
Is there a better method for loading oil into the differential without trying to squeeze a bottle of 600w oil into a fill hole that's almost horizontal?
Thanks in advance for your comments.
Keith True 02-04-2025 05:36 PM
Re: Oil Addition to Differential
Sure,stick a piece of fuel hose on the squirter end,stick it in the hole,hold the bottle vertical,and squeeze it.
Sunny the Model A 02-04-2025 05:42 PM
Suction gun is an easy way. Get yourself one from harbor freight. unscrew the guns lid and fill it up, shove the hose into the fill port and push on the plunger. That's how i do it
1crosscut 02-04-2025 07:01 PM
I found that if you cut the tip on the squeeze bottle pretty short so the opening is large it doesn't take a whole lot of time and effort to get it in.
You could warm the oil in a pan of boiling water to make it flow easier.
nkaminar 02-04-2025 07:24 PM
Little hand pumps and electric pumps are used to fill the fuel tanks of model airplanes. I wonder if one of those would work. There are big sized pumps for larger airplanes.
JayJay 02-04-2025 10:23 PM
I do like crosscut stated: cut the top of the squeeze bottle short and it flows pretty easy.
Charlie Stephens 02-05-2025 12:17 AM
How about a turkey baster from the 99cent store?
Charlie Stephens
Big hammer 02-05-2025 09:39 AM
55 years ago I found my rearend was low of fluid, got some black thick 600w in a quart metal can. It was in the fall a cool, how do I get it in there, found a long hose a funnel and warmed the can on the boiler. Stuck one end in the diff, ran the hose up to the spare tire added the funnel. Poured the warmed black 600w into the funnel and then waited for ever for it to flow down into the differential. Dumb teenager had more time than money LOL
