Old 08-05-2022, 09:34 PM   #1
BoxCar Tom
BoxCar Tom's Avatar
Default What are these, 32 3W rear window pieces?
The attached pictures are from a 2008 EBAY auction. The auction description stated 1932 3W coupe rear window brackets.
The two right angle pieces in the pictures are a mystery. Anybody know what they are? Possibly rear window stops?
The two parts in the bottom of the pictures hold the rear window channel in place. Thanks,
File Type: jpg thumb_32 3W rear win brackets A_1024.jpg (31.4 KB, 230 views)
File Type: jpg thumb_32 3W rear win brackets B_1024.jpg (31.8 KB, 227 views)
BoxCar Tom is offline   Reply With Quote
Old 08-05-2022, 09:46 PM   #2
petehoovie
petehoovie's Avatar
Default Re: What are these, 32 3W rear window pieces?
Old 08-09-2022, 09:44 AM   #3
32phil
Hi Tom
I think you have 2 bottom stops and 2 ends of the window channels that the felt channels sit in.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 08-09-2022, 01:45 PM   #4
alchemy
alchemy's Avatar
Probably about $1,000 worth in the '32 three window world.
alchemy is offline   Reply With Quote
Old 08-09-2022, 01:55 PM   #5
deuce lover
deuce lover's Avatar
I edited the orig pic.Now Pete can make it even better
Old 08-09-2022, 03:14 PM   #6
DavidG
DavidG's Avatar
Phil,
With respect, the two channels at the bottom of the photo are correctly labeled as you note. That tag is not attached to the bracket at the top and those two L-shaped brackets at the top are not rear window stops on any '32 Ford. I'm not even convinced that they are Ford parts.
