The Ford Barn
-   -   What are these, 32 3W rear window pieces? (https://www.fordbarn.com/forum/showthread.php?t=316612)
BoxCar Tom 08-05-2022 09:34 PM
2 Attachment(s)
The attached pictures are from a 2008 EBAY auction. The auction description stated 1932 3W coupe rear window brackets.
The two right angle pieces in the pictures are a mystery. Anybody know what they are? Possibly rear window stops?
The two parts in the bottom of the pictures hold the rear window channel in place. Thanks,
petehoovie 08-05-2022 09:46 PM
Re: What are these, 32 3W rear window pieces?
https://www.fordbarn.com/forum/attac...1&d=1659753179
https://www.fordbarn.com/forum/attac...2&d=1659753179
32phil 08-09-2022 09:44 AM
Hi Tom
I think you have 2 bottom stops and 2 ends of the window channels that the felt channels sit in.
alchemy 08-09-2022 01:45 PM
Probably about $1,000 worth in the '32 three window world.
deuce lover 08-09-2022 01:55 PM
1 Attachment(s)
I edited the orig pic.Now Pete can make it even better
DavidG 08-09-2022 03:14 PM
Phil,
With respect, the two channels at the bottom of the photo are correctly labeled as you note. That tag is not attached to the bracket at the top and those two L-shaped brackets at the top are not rear window stops on any '32 Ford. I'm not even convinced that they are Ford parts.
