Old 07-27-2021, 08:52 AM   #1
erdaviesjr
erdaviesjr's Avatar
Default Broken clutch arm
My clutch quit working on my 31 pickup while driving recently (stays in gear even with clutch depressed) and I managed to limp back home. I found that I have a broken clutch arm with a crack along the shaft. I pulled the transmission and rebuilt it last April, and I wonder if I damaged that arm in the process?? Anyway, I'm hoping that I don't have to pull the transmission again to replace this arm? Is this an easy fix?
erdaviesjr is offline   Reply With Quote
Old 07-27-2021, 09:20 AM   #2
nkaminar
nkaminar's Avatar
Default Re: Broken clutch arm
A photo would help.
Old 07-27-2021, 09:20 AM   #3
jw hash
jw hash's Avatar
clutch arms can break at anytime for a number of reasons. you do not have to pull the trans to replace the arm.
jw hash is offline   Reply With Quote
Old 07-27-2021, 09:29 AM   #4
Will N
Will N's Avatar
The arm is held on by a pin. Should be easy to drive the pin out and take off the arm. I bet the arm cracked at the hole where the pin goes through. Not much metal there. Mine cracked at that spot. Model A suppliers sell a replacement arm, but it doesn't look like an original and it's kind of crude. Better off with an original.
Will N is offline   Reply With Quote
Old 07-27-2021, 09:34 AM   #5
Tacoma Bob
Tacoma Bob's Avatar
I believe Snyder's offers three actually. The "crude" version, a new forged unit and the modern and imo Bullitt proof version.
Tacoma Bob is offline   Reply With Quote
Old 07-27-2021, 01:16 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Not sure I would agree with you. The replacement type below is very nice and difficult for most to distinguish from an original.
https://www.snydersantiqueauto.com/P...earchByKeyword
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-29-2021, 06:53 PM   #7
erdaviesjr
erdaviesjr's Avatar
Thanks everyone for the posts! This really was an easy fix! I bought the replacement from Snyder’s for ab $38 and it took 15 mins to replace and adjust the clutch. Back on the road again!
Old 07-29-2021, 10:08 PM   #8
Bill G
Bill G's Avatar
Yep, easy.
Old 07-27-2021, 09:36 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
Is this the bad dog that is giving you heartburn? Yes, after 90 years they like to break. As others have noted, easy fix. All of the vendors carry the parts you need. I don't think I would go with an original in this case as I have seen many originals crack. See picture of mine below.
The "crude" version is a little longer so the clutch is easier to push if you have leg issues.
Old 07-27-2021, 10:03 AM   #10
erdaviesjr
erdaviesjr's Avatar
Trying to post a pic without much success. I’ll try again later from my computer
Old 07-27-2021, 10:24 AM   #11
goodcar
Common problem. Just replace it and drive on. Many other things will probably break before you have to replace it again.
goodcar is offline   Reply With Quote
Old 07-27-2021, 10:46 AM   #12
Tom Endy
Tom Endy's Avatar
A broken clutch release arm is common. They break at the pin hole, especially the ones that have been modified according to the Ford service bulletin. The after market ones the suppliers sell is bullet proof and is also slightly longer for added leverage. I recommend them, I install them on bell housings I rebuild.
See the attached article.
Tom Endy
Old 07-27-2021, 10:55 AM   #13
Jacksonlll
Jacksonlll's Avatar
When you put on the beefed up arm, be sure you get full range and you can connect the linkage without interference. We had to grind a bit to get things to fit. Good luck. Should not be a hard job.
Old 07-27-2021, 12:20 PM   #14
erdaviesjr
erdaviesjr's Avatar
Here's a pic - had to drastically reduce the size to upload to the forum.
Old 07-29-2021, 10:52 PM   #15
PalAl
PalAl's Avatar
Here is my story...... go to #4
https://www.fordbarn.com/forum/showthread.php?t=280529
PalAl is offline   Reply With Quote
Old 08-02-2021, 01:20 PM   #16
erdaviesjr
erdaviesjr's Avatar
Originally Posted by PalAl View Post
Yikes! Thanks for sharing. Fortunately, my old pin came out pretty easily. I punched it out from the bottom with a good punch and hammer. I could not get the replacement pins to go more than halfway in without excessive pounding with a hammer, so I quit trying and reused the old pin which still has a good, snug fit. And, I fortunately did not damage the bell housing or the throwout bearing inside.
Old 08-02-2021, 08:07 PM   #17
Gene F
Gene F's Avatar
Are we all talking the one inside the bleehousing, or the one outside the bellhousing?
Old 08-02-2021, 09:09 PM   #18
chrs1961815
chrs1961815's Avatar
Outside, the one that attaches the clutch arm to the shaft. He would not be able to knock the bellhousing one out that easy!
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-03-2021, 05:03 AM   #19
dr.j
I thought I saw one several years ago that was "heavy duty" ? Looked far more robust.
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 08-03-2021, 06:16 AM   #20
chrs1961815
You mean one of these? This is what I used when I rebuilt my transmission.
https://www.brattons.com/clutch-release-shaft-arm.html
