Old 04-27-2021, 01:16 PM   #1
gmc4hire
gmc4hire's Avatar
Default Rear spring
OK, I was under my 1928 coupe and noticed that the 2 smallest leaf springs are mounted on the bottom [under the main spring]. Does anyone know why someone would do this?
gmc4hire is offline   Reply With Quote
Old 04-27-2021, 01:38 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Rear spring
Only reason I can think is someone was trying to adjust the ride, so they swapped the top leaves to the bottom to reduce the effective springiness while retaining the right number of leaves for the assembly hardware.
Old 04-27-2021, 01:45 PM   #3
Mulletwagon
Mulletwagon's Avatar
Suspect the ride height was also reduced.
Mulletwagon is offline   Reply With Quote
Old 04-27-2021, 03:06 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
To use them as spacers
Old 04-27-2021, 03:34 PM   #5
d.j. moordigian
d.j. moordigian's Avatar
The top leaf, front AND rear, are beveled too fit the cross member correctly..!
Something to think about..
d.j. moordigian is offline   Reply With Quote
Old 04-28-2021, 09:34 PM   #6
gmc4hire
gmc4hire's Avatar
Update, the top leaf has the "Ford" logo stamped on it, that was cool to see. It also is beveled as stated earlier.
