Old 07-18-2020, 08:09 PM   #1
Digger
Digger's Avatar
Default Dumb question about steering box
I am breaking down, cleaning up, and reassembling my 29/30 pick up. On the steering box, there are two “fillers”. Do I put new lubricant in BOTH of them?
When I do EFV8’s, I use HD corn head grease. ...
Digger is offline   Reply With Quote
Old 07-18-2020, 09:10 PM   #2
Cape Codder
Cape Codder's Avatar
Default Re: Dumb question about steering box
NO. The top one is for adjustment of the steering. The bottom one is for lube. I don't know about the HD Corn Head Grease. Most on this site don't put grease in the steering box. I should of asked is that a two or 7 tooth box. I don't know the arrangement of a 7 tooth.
Cape Codder is offline   Reply With Quote
Old 07-18-2020, 09:29 PM   #3
Digger
Digger's Avatar
Sorry, meant to type John Deere JD corn head grease, I have had success with it in my 33/34 boxes.
Old 07-18-2020, 09:40 PM   #4
chrs1961815
chrs1961815's Avatar
The cornhead grease is probably the way to go with all model a steering boxes because they leak. Many steering boxes use grease anyways, and cornhead is in between.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-18-2020, 09:44 PM   #5
daren007
My two tooth box does not leak.
daren007 is offline   Reply With Quote
Old 07-19-2020, 12:50 AM   #6
woofa.express
woofa.express's Avatar
I remember a statement made by an old school teacher and I quote
"don't be afraid to ask a question regardless of how dumb you think it may be. For if you don't know there will be others who likewise don't know either."
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 07-19-2020, 06:05 AM   #7
Patrick L.
Patrick L.'s Avatar
Then is probably empty !
Sorry, couldn't resist !
Old 07-19-2020, 09:32 AM   #8
Ruth
I was thinking the same!!
Ruth
Old 07-19-2020, 03:55 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Guys, it really is not that difficult to rebuild a Model-A steering gearbox that does not leak. The problem is most 'restorers' only do the job half-way. I can't begin to tell you how many sector bushings I have seen installed incorrectly. Adding to that, the sector shaft has not been polished nor has the bushings been properly fitted with the correct clearance. If the gearbox case and the sector housing are fitted properly with a correct gasket, ...and if the nuts & studs have a trace of liquid teflon sealant on them, they will be fine. For extra insurance, add the tube to the bottom and the 0-ring between the frame and sector housing and you will be set with nary a leak. Don't just assume because yours leaks that everyone else's does too.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
