Old 10-31-2020, 11:46 PM   #1
cnjzdad
Question Stuck Distributor Rotor
Hi there. I’m new to owning a Model A and have a 31 Tudor. Been running good but decided today to set the timing for the first time. Problem I ran into though is that I can’t get the rotor out. Everything I read or videos I watch have everyone just pulling it out. Not happening on mine. So am I missing something about taking the rotor off to do the timing?
cnjzdad is offline   Reply With Quote
Old 11-01-2020, 06:24 AM   #2
aermotor
Default Re: Stuck Distributor Rotor
Should come out - no mechanical fastener holding it.
John
aermotor is offline   Reply With Quote
Old 11-01-2020, 07:37 AM   #3
shew01
shew01's Avatar
Default Stuck Distributor Rotor
Here is a picture. It’s a friction fit for the rotor. If you remove the part of the distributor body that has the spark plug electrodes on it (as removed in the picture), the rotor may be easier to remove. (The distributor body is a friction fit too. Once you release the two spring clips that hold on the distributor cap, the distributor body should lift straight up. You may need to wiggle it a bit to get it free.)
Old 11-01-2020, 08:37 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
I have some rotors that fit very tight on the rotor and cannot be easily removed. Pry the rotor up and break it if necessary. Replace it with a new one. The cam could also be the culprit. If a new rotor fiits too tightly, then try using another cam.
Bob Bidonde
Old 11-01-2020, 10:11 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
Adjust the points and check the timing, it may not even need adjustment, checking the timing is described in the owners instruction book
Old 11-01-2020, 11:46 AM   #6
cnjzdad
Thanks everyone for your replies. Thought I was missing something simple but guess not. It’s stuck. ��
Old 11-01-2020, 05:08 PM   #7
cnjzdad
Update: I got the rotor off with a couple taps from under it. Glad to know it wasn’t me. Thanks for the responses.
Old 11-01-2020, 05:32 PM   #8
shew01
shew01's Avatar
Yay! Good job. :-)
Old 11-02-2020, 05:49 PM   #9
old31
Good job CN.
Next you will be rebuilding the distributor. Then the engine, then the paint, then the glass, then the upholstery, then the tires, then the brakes, then the pinstriping.
It's called Model A project creep. Almost as deadly as the corana virus.
old31 is offline   Reply With Quote
Old 11-02-2020, 06:44 PM   #10
JOHN CT
JOHN CT's Avatar
Thumbs up Re: Stuck Distributor Rotor
Originally Posted by old31 View Post
Good job CN.
And then we must get another one
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 11-02-2020, 07:46 PM   #11
Synchro909
Synchro909's Avatar
Talking Re: Stuck Distributor Rotor
I have a theory that my first Model A did unspeakable things at night in the garage with the lawn mower! No more mowers but I now have 4 Model As.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 11-03-2020, 12:26 AM   #12
cnjzdad
Well I’ve owned two Jeeo CJ’s so I quickly learned that Jeeo stood for ‘Just Empty Every Pocket’. Lol
Old 11-03-2020, 12:05 PM   #13
Purdy Swoft
Purdy Swoft's Avatar
Thats about what they will do . I have also had jeeps .
