The Ford Barn
-   -   Stuck Distributor Rotor (https://www.fordbarn.com/forum/showthread.php?t=289535)
cnjzdad 10-31-2020 11:46 PM
Hi there. I’m new to owning a Model A and have a 31 Tudor. Been running good but decided today to set the timing for the first time. Problem I ran into though is that I can’t get the rotor out. Everything I read or videos I watch have everyone just pulling it out. Not happening on mine. So am I missing something about taking the rotor off to do the timing?
aermotor 11-01-2020 06:24 AM
Re: Stuck Distributor Rotor
Should come out - no mechanical fastener holding it.
John
shew01 11-01-2020 07:37 AM
Here is a picture. It’s a friction fit for the rotor. If you remove the part of the distributor body that has the spark plug electrodes on it (as removed in the picture), the rotor may be easier to remove. (The distributor body is a friction fit too. Once you release the two spring clips that hold on the distributor cap, the distributor body should lift straight up. You may need to wiggle it a bit to get it free.)
https://uploads.tapatalk-cdn.com/202...7946d9a44d.jpg
Bob Bidonde 11-01-2020 08:37 AM
I have some rotors that fit very tight on the rotor and cannot be easily removed. Pry the rotor up and break it if necessary. Replace it with a new one. The cam could also be the culprit. If a new rotor fiits too tightly, then try using another cam.
Kurt in NJ 11-01-2020 10:11 AM
Adjust the points and check the timing, it may not even need adjustment, checking the timing is described in the owners instruction book
cnjzdad 11-01-2020 11:46 AM
Thanks everyone for your replies. Thought I was missing something simple but guess not. It’s stuck. ��
cnjzdad 11-01-2020 05:08 PM
Update: I got the rotor off with a couple taps from under it. Glad to know it wasn’t me. Thanks for the responses.
shew01 11-01-2020 05:32 PM
Yay! Good job. :-)
old31 11-02-2020 05:49 PM
Good job CN.
Next you will be rebuilding the distributor. Then the engine, then the paint, then the glass, then the upholstery, then the tires, then the brakes, then the pinstriping.
It's called Model A project creep. Almost as deadly as the corana virus.
JOHN CT 11-02-2020 06:44 PM
Originally Posted by old31 (Post 1948138)
Good job CN.
And then we must get another one :):D
Synchro909 11-02-2020 07:46 PM
I have a theory that my first Model A did unspeakable things at night in the garage with the lawn mower! No more mowers but I now have 4 Model As.
cnjzdad 11-03-2020 12:26 AM
Well I’ve owned two Jeeo CJ’s so I quickly learned that Jeeo stood for ‘Just Empty Every Pocket’. Lol
Purdy Swoft 11-03-2020 12:05 PM
Thats about what they will do . I have also had jeeps .
