Old 04-13-2020, 01:15 PM   #1
Tim Ayers
Default Are these those special U joint washers?
I know I have them in my stash piles somewhere, but are these two those special U joint washers? If not, does anyone have one or two they'd be willing to sell?
Thanks,
Old 04-13-2020, 01:22 PM   #2
DavidG
DavidG's Avatar
Default Re: Are these those special U joint washers?
Looks like you have the real deal, especially given the marks created by the shake-proof lock washer that was originally used for that application.
Old 04-13-2020, 01:25 PM   #3
35fordtn
35fordtn's Avatar
Yes, those are the correct ones. There is also a truck one that is similar that can work as well.
Old 04-13-2020, 01:39 PM   #4
Tim Ayers
Thanks, gentlemen. David, agree about the marks.
In a previous post, someone mentioned that these are actually a "spring"? Are they designed to allow some movement under load?
Old 04-13-2020, 02:24 PM   #5
hotrodart
hotrodart's Avatar
No.....they are bellows washers.....crank the bolt down to the correct torque value and there will be no movement allowed.
hotrodart is offline   Reply With Quote
Old 04-13-2020, 02:27 PM   #6
42merc
42merc's Avatar
I don't think they are a spring. I believe they are a "bellvill" washer.
You can "Google" it.
Edit: belleville, sorry
42merc is offline   Reply With Quote
Old 04-13-2020, 02:33 PM   #7
Tim Ayers
Thank you, gentlemen. Makes sense.
https://en.wikipedia.org/wiki/Belleville_washer
Old 04-13-2020, 03:17 PM   #8
hotrodart
hotrodart's Avatar
You are correct in the technica/patentedl name "Belleville".......they are spring washers however, specifically designed for axial load applications.
Old 04-14-2020, 07:18 AM   #9
42merc
42merc's Avatar
load applications.
I agree.
I'm familiar with them from the electrical industry.
Swichgear, buss & terminations are a major consumer of belleville washers.
Old 04-14-2020, 07:43 AM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
I agree.
We also used many Belleville/spring loading type washers during the manufacture of power tools and industrial equipment at the company I worked for.
John
Old 04-14-2020, 08:07 AM   #11
rockfla
rockfla's Avatar
As I sell "Belleville" washers almost "daily" there are over 1500 listed combinations of these washers SO there are (or can be) VERY technical in both materials, thickness, load range, etc etc SO ordering a "replacement" could be catastrophe IF you don't know all the particulars!!!!! Just saying
I might also add......"Some" can get quite pricey too!!!!
