The Ford Barn
-   -   Are these those special U joint washers? (https://www.fordbarn.com/forum/showthread.php?t=279380)
Tim Ayers 04-13-2020 01:15 PM
3 Attachment(s)
I know I have them in my stash piles somewhere, but are these two those special U joint washers? If not, does anyone have one or two they'd be willing to sell?
Thanks,
DavidG 04-13-2020 01:22 PM
Re: Are these those special U joint washers?
Looks like you have the real deal, especially given the marks created by the shake-proof lock washer that was originally used for that application.
35fordtn 04-13-2020 01:25 PM
Yes, those are the correct ones. There is also a truck one that is similar that can work as well.
Tim Ayers 04-13-2020 01:39 PM
Thanks, gentlemen. David, agree about the marks.
In a previous post, someone mentioned that these are actually a "spring"? Are they designed to allow some movement under load?
hotrodart 04-13-2020 02:24 PM
No.....they are bellows washers.....crank the bolt down to the correct torque value and there will be no movement allowed.
42merc 04-13-2020 02:27 PM
I don't think they are a spring. I believe they are a "bellvill" washer.
You can "Google" it.
Edit: belleville, sorry
Tim Ayers 04-13-2020 02:33 PM
Thank you, gentlemen. Makes sense.
https://en.wikipedia.org/wiki/Belleville_washer
hotrodart 04-13-2020 03:17 PM
You are correct in the technica/patentedl name "Belleville".......they are spring washers however, specifically designed for axial load applications.
42merc 04-14-2020 07:18 AM
load applications.
I agree.
I'm familiar with them from the electrical industry.
Swichgear, buss & terminations are a major consumer of belleville washers.
JM 35 Sedan 04-14-2020 07:43 AM
Originally Posted by 42merc (Post 1874186)
I agree.
We also used many Belleville/spring loading type washers during the manufacture of power tools and industrial equipment at the company I worked for.
rockfla 04-14-2020 08:07 AM
As I sell "Belleville" washers almost "daily" there are over 1500 listed combinations of these washers SO there are (or can be) VERY technical in both materials, thickness, load range, etc etc SO ordering a "replacement" could be catastrophe IF you don't know all the particulars!!!!! Just saying
I might also add......"Some" can get quite pricey too!!!!
