Old 07-01-2019, 07:55 AM   #1
Standing Elk
Default K&N part number
Does anyone have the correct (K&N) part number for both the standard length and the extended length air filter cartridges for the Air Maze? If I can find the correct K&N pt. number I should be able to get them locally. Thanks
Standing Elk is offline   Reply With Quote
Old 07-01-2019, 08:07 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: K&N part number
I use K&N E-9257. You will need to extend the Air Maze center bolt. There may be other part #'s that fit.
I'm sure you will hear from a lot of members that say you don't need an air filter. My response is if I don't need an air filter, why do I have to clean it all the time...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 07-01-2019, 08:16 AM   #3
fuzes45
Originally Posted by standing elk View Post
does anyone have the correct (k&n) part number for both the standard length and the extended length air filter cartridges for the air maze? If i can find the correct k&n pt. Number i should be able to get them locally. Thanks
e-3050 3.5 "
e-9257 5.5 "
e-*2040 6.625 "
fuzes45 is offline   Reply With Quote
Old 07-01-2019, 08:20 AM   #4
Joe K
Joe K's Avatar
Air filter keeps your oil cleaner, and cuts down on cylinder wear.
Lack of a filter is of the reasons that a Model A engine typically needs rebuilding at 60K-80K miles while a modern engine will do double if not treble that.
My 29CC pickup showed 140K original miles and it was on it SECOND red engine (probably a Sears or Allstate replacement) - and that one worn out.
Joe K
Shudda kept the horse.
Old 07-01-2019, 08:23 AM   #5
alexiskai
alexiskai's Avatar
Word of warning, before you get the extra-long one, go down to your local hardware store and see whether they actually carry a bolt that's long enough. If memory serves, I had to use the E-9257 because that's the longest bolt they had at my local store. Also get a fender washer to help distribute the force on the end of the filter.
Old 07-01-2019, 08:49 AM   #6
Y-Blockhead
Use a piece of all-thread if you can't find a bolt long enough.
